[GRASS-dev] Re: [GRASS-SVN] r44977 - in grass/trunk: gui/wxpython/xml imagery imagery/i.evapo.PT
Yann Chemin yann.chemin at gmail.com
Wed Jan 12 17:27:45 EST 2011
Hi Martin I agree with all that you say, my mistakes, and sorry for
still making some.
However, parameters names are certainly specialized
abbreviations/names, but not strange to certain fields of
hydrology/RS.
I'll run through those and correct.
Yann
On 13 January 2011 02:48, Martin Landa <landa.martin at gmail.com> wrote:
> 2011/1/12 Yann Chemin <yann.chemin at gmail.com>:
>>>> yeah no problem to move to small caps, initial reason was that it was
>>>> Family names abbreviation...
> before adding new and new modules I would really like some discussion
> on ML if the module needs to be in trunk. E.g. at least most of
> modules which you have added recently breaks syntax convencion, eg.
> 1) don't use caps in module name
> 2) missing keywords
> 3) Flag's description should start with caps
> 4) Completely strange parameter names, besides caps again.
> I'ts just subset, unfortunately...
> Martin
> Description:
>  Evapotranspiration Calculation Prestley and Taylor formulation, 1972.
> Usage:
>  i.evapo.PT [-z] RNET=[W/m2] G0=[W/m2] TEMPKA=[K] PATM=[millibars]
>   PT=[-] output=[mm/d] [--overwrite] [--verbose] [--quiet]
> Flags:
>  -z   set negative ETa to zero
>  --o   Allow output files to overwrite existing files
>  --v   Verbose module output
>  --q   Quiet module output
> Parameters:
>    RNET   Name of Net Radiation raster map
>      G0   Name of Soil Heat Flux raster map
>  TEMPKA   Name of air temperature raster map
>    PATM   Name of Atmospheric Pressure raster map
>      PT   Prestley-Taylor Coefficient
>           default: 1.26
>  output   Name of output Evapotranspiration layer
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
Yann Chemin
www.csu.edu.au
