[GRASS-dev] Re: [GRASS-SVN] r44977 - in grass/trunk: gui/wxpython/xml imagery imagery/i.evapo.PT
Yann Chemin yann.chemin at gmail.com
Wed Jan 12 17:42:03 EST 2011
oh well Martin, you are also right about the parameter names, too
abbreviated, steeper learning curve.
I see you already corrected what you mentioned was not the convention
over the night. thanks
On 13 January 2011 09:27, Yann Chemin <yann.chemin at gmail.com> wrote:
> Hi Martin I agree with all that you say, my mistakes, and sorry for
> still making some.
> However, parameters names are certainly specialized
> abbreviations/names, but not strange to certain fields of
> hydrology/RS.
> I'll run through those and correct.
> Yann
> On 13 January 2011 02:48, Martin Landa <landa.martin at gmail.com> wrote:
>> 2011/1/12 Yann Chemin <yann.chemin at gmail.com>:
>>>>> yeah no problem to move to small caps, initial reason was that it was
>>>>> Family names abbreviation...
>> before adding new and new modules I would really like some discussion
>> on ML if the module needs to be in trunk. E.g. at least most of
>> modules which you have added recently breaks syntax convencion, eg.
>> 1) don't use caps in module name
>> 2) missing keywords
>> 3) Flag's description should start with caps
>> 4) Completely strange parameter names, besides caps again.
>> I'ts just subset, unfortunately...
>> Martin
>> Description:
>>  Evapotranspiration Calculation Prestley and Taylor formulation, 1972.
>> Usage:
>>  i.evapo.PT [-z] RNET=[W/m2] G0=[W/m2] TEMPKA=[K] PATM=[millibars]
>>   PT=[-] output=[mm/d] [--overwrite] [--verbose] [--quiet]
>> Flags:
>>  -z   set negative ETa to zero
>>  --o   Allow output files to overwrite existing files
>>  --v   Verbose module output
>>  --q   Quiet module output
>> Parameters:
>>    RNET   Name of Net Radiation raster map
>>      G0   Name of Soil Heat Flux raster map
>>  TEMPKA   Name of air temperature raster map
>>    PATM   Name of Atmospheric Pressure raster map
>>      PT   Prestley-Taylor Coefficient
>>           default: 1.26
>>  output   Name of output Evapotranspiration layer
>> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
> Yann Chemin
> www.csu.edu.au
Yann Chemin
www.csu.edu.au
