[GRASS-dev] v.out.ogr: major speed-up to go into 6.4.1?
Martin Landa landa.martin at gmail.com
Fri Jan 14 13:09:08 EST 2011
2011/1/14 Benjamin Ducke <benjamin.ducke at oxfordarch.co.uk>:
> Question is: what to do with this? I would like to have it in
> 6.4.1 and believe that the change is actually very small, but
> I understand that v.out.ogr is a very critical modules and so
> every change in there needs to well-tested.
> I have some resources for working on GRASS contributions next week,
> but I need to plan them well. So if there is a realistic chance that
> this can go into 6.4.1, I will do some in-depth testing next week
> to make sure all works well.
> If not, I can check this into 6.5 and then we give it enough time
> to mature for 6.4.2.
my opinion: first apply the change in trunk and devbr6. After some
testing it can go to relbr64. Currently we are in RC stage, only
bugfixes allowed. So in the best case it could be available in GRASS
6.4.2.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
