[GRASS-dev] v.out.ogr: major speed-up to go into 6.4.1?
    Benjamin Ducke
    benjamin.ducke at oxfordarch.co.uk
    Fri Jan 14 12:57:00 EST 2011
Dear all,
I have just reviewed v.out.ogr and where it spends those
massive amounts of time it needs to export larger vector maps.
Turns out that it issues a new SQL SELECT statement for every
single attribute it wants to export.
So I rearranged the code to use only one SQL SELECT statement that
fetches all records at once (same as what v.db.select does).
Essentially, I moved the SQL SELECT out of mk_atts() and into the
calling function, where it is now executed only once.
After that fix, I was able to export a vector map with 220.000 points
within 10 secs, instead of originally ca. 100 mins. Go figure out the
speed-up factor, it's ridulous! Granted, my data has a very simple
attribute table and for more complex table structures, the factor
may be smaller (v.out.ogr re-examines the field types for every
record, so there is still some room for optimization).
Question is: what to do with this? I would like to have it in
6.4.1 and believe that the change is actually very small, but
I understand that v.out.ogr is a very critical modules and so
every change in there needs to well-tested.
I have some resources for working on GRASS contributions next week,
but I need to plan them well. So if there is a realistic chance that
this can go into 6.4.1, I will do some in-depth testing next week
to make sure all works well.
If not, I can check this into 6.5 and then we give it enough time
to mature for 6.4.2.
Also: I am getting really annoyed by having to supply those OGR
"lco=" (or was it "dsco="? See, that's what I mean...)
options for creating 3D Shapefiles. How about, similar
to "-e" I add another flag "-z" which automatically creates 3D
output in case the input is a 3D GRASS map and the output are
Shapefiles? It wouldn't change anything about the default behaviour.
Cheers,
Ben
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
