[GRASS-dev] Re: [GRASS GIS] #1259: g.remove deletes raster maps by default: could delete the wrong map
GRASS GIS trac at osgeo.org
Fri Jan 14 19:26:35 EST 2011
 Reporter:  benducke                    |       Owner:  grass-dev@…
     Type:  enhancement                 |      Status:  new
 Priority:  normal                      |   Milestone:  7.0.0
Component:  Default                     |     Version:  svn-trunk
 Keywords:  g.remove, raster, deletion  |    Platform:  Unspecified
      Cpu:  Unspecified                 |
Comment(by martinl):
 From ML
 It's "default" behaviour. If the first argument doesn't contain an "="
 character, it's assumed to be the value of the first registered
 option.
 This behaviour applies to all modules. Currently, there isn't any way
 for individual commands to disable it without resorting to "hacks",
 e.g. making the first option a dummy option (which would then show up
 in the help output and manual page).
 Glynn
Ticket URL: <http://trac.osgeo.org/grass/ticket/1259#comment:2>
