[GRASS-dev] Re: [GRASS GIS] #1257: Georectifier is broken
GRASS GIS trac at osgeo.org
Sun Jan 16 22:27:19 EST 2011
 Reporter:  cmbarton      |       Owner:  grass-dev@…
     Type:  defect        |      Status:  new
 Priority:  blocker       |   Milestone:  6.4.1
Component:  wxGUI         |     Version:  unspecified
 Keywords:  georectifier  |    Platform:  MacOSX
      Cpu:  OSX/Intel     |
Comment(by cmbarton):
 I found where the error is and can prevent it. But I don't yet know why
 this is a problem. Hopefully Markus M will have some ideas. The errors are
 generated by...[[BR]]
 self.OnZoomToMap(None) in line 870
 and a similar call of ...[[BR]]
 self.parent.TgtMapWindow.ZoomToMap(layers =
 self.parent.TgtMap.GetListOfLayers()) in line 2739
 If I comment out these lines, both source and target maps open fine.
 Initializing the target map window with a zoom to map extents is probably
 a good idea. So the root cause of this error still needs to be found.
 These both do something that causes a crash on the Mac.
 Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1257#comment:11>
