[GRASS-dev] Re: [GRASS GIS] #1257: Georectifier is broken
GRASS GIS trac at osgeo.org
Mon Jan 17 01:44:39 EST 2011
 Reporter:  cmbarton      |       Owner:  grass-dev@…
     Type:  defect        |      Status:  new
 Priority:  blocker       |   Milestone:  6.4.1
Component:  wxGUI         |     Version:  unspecified
 Keywords:  georectifier  |    Platform:  MacOSX
      Cpu:  OSX/Intel     |
Comment(by cmbarton):
 Here is more info.
 Both of the zoom lines call an instance of BufferedMap.ZoomToMap() in
 mapdisplay_window.py
 ZoomToMap() calls UpdateMap, which does a GetClientSize(), which returns
 (0,0). This is the problem. Previous calls to UpdateMap return non-zero
 values for GetClientSize().
 Prior to calling UpdateMap, ZoomToMap calls an instance of Map.GetRegion()
 in render.py. This seems to go OK, but I can't tell for sure. GetRegion
 does GISRC switching.
 So any ideas here?
 Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1257#comment:12>
