[GRASS-dev] GRASS 7 CLI startup
Mon Jan 24 22:23:19 EST 2011
Markus Neteler wrote:
> > The "-text" option doesn't work in 7.0. All curses-based functionality
> > has been removed from 7.0.
> I wonder if it could come back Python-based:
There's no fundamental reason why not. The -gui case just executes
gis_set.py, which updates $GISRC and returns a success/failure
indication. Although, writing something similar using Python and
curses would be a fair amount of work (you'd basically end up porting
most of the old Vask library to Python as well as set_data itself).
