[GRASS-dev] Re: [GRASS GIS] #699: v.buffer segfault: in Vect_get_isle_points()
GRASS GIS trac at osgeo.org
Fri Jan 28 10:16:56 EST 2011
 Reporter:  neteler   |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  normal    |   Milestone:  7.0.0
Component:  Vector    |     Version:  6.4.0 RCs
 Keywords:  v.buffer  |    Platform:  All
      Cpu:  All       |
Comment(by mmetz):
 Replying to [comment:9 mmetz]:
 > The second bug should now be fixed in r45219, r45220, r45221 (7.0, 6.5,
 6.4), working on Linux 32bit and 64bit.
 Correction, it works on Linux 32bit and Windows, but not always on Linux
 64bit. On Linux 64 bit, v.buffer2 (and v.parallel2) create sometimes zero-
 size areas, the bug is somewhere in the vector libs, more specifically in
 buffer2.c and/or dgraph.c.
 BTW, buffering works with the original v.buffer module (slightly modified)
 where v.buffer2 fails. Umh, and v.buffer is up to 10x faster and easier to
 maintain than v.buffer2...
 Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/699#comment:10>
