[GRASS-dev] MinGW/MSYS Build
Huddleston, John Huddleston at cira.colostate.edu
Sat Jan 29 11:24:35 EST 2011
Thank you Glynn,
I just needed the base libraries to build GSTAT (http://www.gstat.org/download.html); which, I just finished today.
I contacted Colin Harrison to get the Xming X11 libraries.
Based on your input; though, I'll not pursue this any further.
John
________________________________________
Sent: Friday, January 28, 2011 10:42 PM
To: Huddleston, John
Cc: grass-dev at lists.osgeo.org
Subject: Re: [GRASS-dev] MinGW/MSYS Build
Huddleston, John wrote:
> I have starting building GRASS6.4.1RC1 under the native Windows
> MinGW/MSYS (not Cygwin) environment.
> Now I am up to the point where it requires the X11 libraries. Does
> anyone have any experience building X11 under MinGW? Should I be
> using XFree86-4.8.0 or some other source.
There isn't much point building GRASS with X11 support under native
Windows. The standalone display drivers (d.mon etc) don't work for
reasons unrelated to X.
If you need to use d.mon on Windows, Cygwin is the only option.
