[GRASS-dev] [GRASS GIS] #1269: ctypesgen doesn't handle OS X framework option
GRASS GIS trac at osgeo.org
Fri Jan 28 12:50:17 EST 2011
 Reporter:  kyngchaos    |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.5.0
Component:  Default      |     Version:  svn-develbranch6
 Keywords:  ctypes       |    Platform:  MacOSX
      Cpu:  Unspecified  |
 See http://code.google.com/p/ctypesgen/issues/detail?id=11
 Update GRASS' copy when it's fixed.
 Affects linking with the new GDAL 1.8 framework gdal-config which returns
 a -framework option instead of the old -L/-l unix compatibility combo.
 Until then, I have some ideas for a workaround that I need to explore.
 One workaround is to change the GDAL 1.8 gdal-config back to the old
 options:
 CONFIG_LIBS="-L/Library/Frameworks/GDAL.framework/unix/lib -lgdal"
Ticket URL: <http://trac.osgeo.org/grass/ticket/1269>
