[GRASS-dev] Re: [GRASS GIS] #699: v.buffer segfault: in Vect_get_isle_points()
GRASS GIS trac at osgeo.org
Fri Jan 28 16:15:01 EST 2011
 Reporter:  neteler   |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  normal    |   Milestone:  7.0.0
Component:  Vector    |     Version:  6.4.0 RCs
 Keywords:  v.buffer  |    Platform:  All
      Cpu:  All       |
Comment(by marisn):
 Could this be some int overflow? This is output from 6.5 on AMD64.
 D3/3: Vect_get_area_isle(): area = 2 isle = 19
 D3/3:   -> isle = 134
 D3/3: Vect_get_isle_points(): isle = 134
 D3/3:   n_lines = 1
 D3/3:   append line(0) = -976
 D3/3: Vect_read_line()
 D3/3: V2_read_line_nat(): line = 976
 D3/3: Vect__Read_line_nat: offset = 160553
 D3/3:     type = 4, do_cats = 0 dead = 0
 D3/3:     n_points = 11
 D3/3:     off = 160734
 D3/3:   line n_points = 11
 D3/3:   isle n_points = 11
 D3/3: Vect_get_area_isle(): area = 2 isle = 20
 D3/3:   -> isle = 137
 D3/3: Vect_get_isle_points(): isle = 137
 D3/3:   n_lines = 1
 D3/3:   append line(0) = -1002
 D3/3: V2_read_line_nat(): line = 1002
 D3/3: Vect__Read_line_nat: offset = 165931
 D3/3:     n_points = 11
 D3/3:     off = 166112
 D3/3: Vect_get_area_isle(): area = 2 isle = 21
 D3/3:   -> isle = 175
 D3/3: Vect_get_isle_points(): isle = 175
 D3/3:   n_lines = 1
 D3/3:   append line(0) = -1233
 D3/3: V2_read_line_nat(): line = 1233
 D3/3: Vect__Read_line_nat: offset = 206334
 D3/3:     n_points = 11
 D3/3:     off = 206515
 D3/3: Vect_get_area_isle(): area = 2 isle = 22
 ==12849== Invalid read of size 4
 ==12849==    at 0x4E43509: Vect_get_area_isle (area.c:288)
 ==12849==    by 0x4E3D64D: Vect_area_buffer2 (buffer2.c:1096)
 ==12849==    by 0x402D6E: main (main.c:478)
 ==12849==  Address 0xdcfc978 is 0 bytes after a block of size 88 alloc'd
 ==12849==    at 0x4C262CA: malloc (in /usr/lib64/valgrind
 /vgpreload_memcheck-amd64-linux.so)
 ==12849==    by 0x52A2027: G__realloc (alloc.c:109)
 ==12849==    by 0x5D2BAFE: dig_area_alloc_isle (struct_alloc.c:333)
 ==12849==    by 0x5D27E56: dig_Rd_P_area (plus_struct.c:368)
 ==12849==    by 0x5D25045: dig_load_plus (plus.c:312)
 ==12849==    by 0x4E497C5: Vect_open_topo (open.c:751)
 ==12849==    by 0x4E4A0F2: Vect__open_old (open.c:229)
 ==12849==    by 0x40269A: main (main.c:302)
 ==12849==
 D3/3:   -> isle = 0
 ==12849==    at 0x4E43521: Vect_get_area_isle (area.c:288)
 ==12849==
 D3/3: Vect_get_isle_points(): isle = 0
 ==12849== Use of uninitialised value of size 8
 ==12849==    at 0x4E43145: Vect_get_isle_points (area.c:118)
 ==12849==    by 0x4E3D65A: Vect_area_buffer2 (buffer2.c:1097)
 ==12849==
 ==12849==  Address 0x30 is not stack'd, malloc'd or (recently) free'd
 ==12849==
 ==12849==
 ==12849== Process terminating with default action of signal 11 (SIGSEGV)
 ==12849==  Access not within mapped region at address 0x30
 ==12849==  If you believe this happened as a result of a stack
 ==12849==  overflow in your program's main thread (unlikely but
 ==12849==  possible), you can try to increase the size of the
 ==12849==  main thread stack using the --main-stacksize= flag.
 ==12849==  The main thread stack size used in this run was 8388608.
 ==12849==
 ==12849== HEAP SUMMARY:
 ==12849==     in use at exit: 7,945,280 bytes in 139,148 blocks
 ==12849==   total heap usage: 139,617 allocs, 469 frees, 8,023,374 bytes
 allocated
 ==12849==
 ==12849== LEAK SUMMARY:
 ==12849==    definitely lost: 4,373 bytes in 13 blocks
 ==12849==    indirectly lost: 240 bytes in 10 blocks
 ==12849==      possibly lost: 0 bytes in 0 blocks
 ==12849==    still reachable: 7,940,667 bytes in 139,125 blocks
 ==12849==         suppressed: 0 bytes in 0 blocks
 ==12849== Rerun with --leak-check=full to see details of leaked memory
 ==12849==
 ==12849== For counts of detected and suppressed errors, rerun with: -v
 ==12849== Use --track-origins=yes to see where uninitialised values come
 from
 ==12849== ERROR SUMMARY: 14 errors from 8 contexts (suppressed: 6 from 6)
 Segmentation fault
Ticket URL: <http://trac.osgeo.org/grass/ticket/699#comment:11>
