[GRASS-dev] Re: [GRASS GIS] #699: v.buffer segfault: in Vect_get_isle_points()
GRASS GIS trac at osgeo.org
Sat Jan 29 04:31:41 EST 2011
 Reporter:  neteler   |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  normal    |   Milestone:  7.0.0
Component:  Vector    |     Version:  6.4.0 RCs
 Keywords:  v.buffer  |    Platform:  All
      Cpu:  All       |
Comment(by mmetz):
 Replying to [comment:11 marisn]:
 > Could this be some int overflow? This is output from 6.5 on AMD64.
 > D3/3: Vect_get_area_isle(): area = 2 isle = 22
 > D3/3:   -> isle = 0
 > Segmentation fault
 This should be fixed as of r45178 from 1/25/2011. Just to be sure, can you
 confirm that the vector libs in your local copy of 6.5 are at least
 r45178, better 45217? Thanks!
 Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/699#comment:12>
