[GRASS-dev] adding 2 more modules to G7 SVNimagery
Yann Chemin
yann.chemin at gmail.com
Mon Jan 31 23:11:28 EST 2011
Looking at the various i.evapo.* modules, it will be a cumbersome task
to fuse them into one code, and a even more confusing input
arrangement for the user.
What are other options within Grass 7 experimental?
On 24 January 2011 08:24, Yann Chemin <yann.chemin at gmail.com> wrote:
> Thank you Soeren
> Most of this request is the process I am going through with few
> students/colleagues now for the i.evapo.* modules, the most
> significant users orientated output being located in
> grass-promo/tutorials/grass_landsat5_ETa and friends as this is the
> most used level.
> A deeper level is i.eb.* where one can model thermodynamic parts of
> the sensible heat flux. As seen in i.eb.h_* there Monin-Obhukov length
> is defined by sensible heat flux, but defines the diabetic corrections
> (psi_*), so most of the time an iteration process is adopted to solve
> the system. i.eb.* are designed to give most controls in solving this
> through scripting without dwelling in those standard equations.
> In R (RemoteSensing) and in a python lib, all this is available as API
> for manipulations as high-level scripting permit it.
> Yann Chemin
> www.csu.edu.au
> On 24/01/2011, at 7:45, Soeren Gebbert <soerengebbert at googlemail.com> wrote:
>> Hello Yann,
>> while adding new i.eb.* modules it would be great if you can check
>> this ticket: http://trac.osgeo.org/grass/ticket/899
>> Maybe it is obsolete now?
>> Best regards
>> Soeren
>> 2011/1/23 Yann Chemin <yann.chemin at gmail.com>:
>>> Yes theoretically same for i.eb.* modules. Practically, it will be
>>> some work and maybe creating maintenance trouble.
>>> When I was thinking about i.eb.toolbox two issues were there first:
>>> 1-Coding blocks from each module to be kept separated somehow for
>>> maintenance/bug fixing reasons
>>> 2-possibility to have a module tab dedicated to each type of tool,
>>> with the possibility of input parameters to appear in two or more
>>> tabs.
>>> Rest is sweat and debugging and unforeseen problems
>>> I would appreciate comments from experienced coders about integrating
>>> many tools in one.
>>> Yann
>>> Yann Chemin
>>> www.csu.edu.au
>>> On 23/01/2011, at 21:05, Markus Neteler <neteler at osgeo.org> wrote:
>>>> Hi Yann,
>>>> On 1/23/11, Yann Chemin <yann.chemin at gmail.com> wrote:
>>>>> Hello,
>>>>> I would like to complete the i.evapo.* series of modules from
>>>>> grass-addons/imagery/gipe with these two last ones.
>>>>> i.evapo.potrad: potential radiation (Bastiaanssen, 1995)
>>>>> i.evapo.senay: Actual evapotranspiration (Senay, 2007)
>>>> would it be possible to make one single i.evapo module
>>>> and manage the methods via method=xx parameter?
>>>> Markus
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
Yann Chemin
