[GRASS-dev] adding 2 more modules to G7 SVNimagery
Yann Chemin
yann.chemin at gmail.com
Sun Jan 23 16:24:20 EST 2011
Thank you Soeren
Most of this request is the process I am going through with few
students/colleagues now for the i.evapo.* modules, the most
significant users orientated output being located in
grass-promo/tutorials/grass_landsat5_ETa and friends as this is the
most used level.
A deeper level is i.eb.* where one can model thermodynamic parts of
the sensible heat flux. As seen in i.eb.h_* there Monin-Obhukov length
is defined by sensible heat flux, but defines the diabetic corrections
(psi_*), so most of the time an iteration process is adopted to solve
the system. i.eb.* are designed to give most controls in solving this
through scripting without dwelling in those standard equations.
In R (RemoteSensing) and in a python lib, all this is available as API
for manipulations as high-level scripting permit it.
Yann Chemin
www.csu.edu.au
On 24/01/2011, at 7:45, Soeren Gebbert <soerengebbert at googlemail.com> wrote:
> Hello Yann,
> while adding new i.eb.* modules it would be great if you can check
> this ticket: http://trac.osgeo.org/grass/ticket/899
> Maybe it is obsolete now?
> Best regards
> Soeren
> 2011/1/23 Yann Chemin <yann.chemin at gmail.com>:
>> Yes theoretically same for i.eb.* modules. Practically, it will be
>> some work and maybe creating maintenance trouble.
>> When I was thinking about i.eb.toolbox two issues were there first:
>> 1-Coding blocks from each module to be kept separated somehow for
>> maintenance/bug fixing reasons
>> 2-possibility to have a module tab dedicated to each type of tool,
>> with the possibility of input parameters to appear in two or more
>> tabs.
>> Rest is sweat and debugging and unforeseen problems
>> I would appreciate comments from experienced coders about integrating
>> many tools in one.
>> Yann
>> Yann Chemin
>> www.csu.edu.au
>> On 23/01/2011, at 21:05, Markus Neteler <neteler at osgeo.org> wrote:
>>> Hi Yann,
>>> On 1/23/11, Yann Chemin <yann.chemin at gmail.com> wrote:
>>>> Hello,
>>>> I would like to complete the i.evapo.* series of modules from
>>>> grass-addons/imagery/gipe with these two last ones.
>>>> i.evapo.potrad: potential radiation (Bastiaanssen, 1995)
>>>> i.evapo.senay: Actual evapotranspiration (Senay, 2007)
>>> would it be possible to make one single i.evapo module
>>> and manage the methods via method=xx parameter?
>>> Markus
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
