[GRASS-dev] Segmentation fault using v.in.lidar
Markus Metz
markus.metz.giswork at googlemail.com
Wed Jul 13 11:54:47 EDT 2011
On Wed, Jul 13, 2011 at 2:59 PM, <Doug_Newcomb at fws.gov> wrote:
> In the short term, use the las2las command from liblas.org to merge your .las files into a single las file and then process the one file. You will have to watch out for the 4 billion point limit that is currently in the LAS file format, but for most folks that's not an issue.
In GRASS 6, the limit is somewhere lower than 2 billion features
because GRASS vector files can't be larger than 2GB. In GRASS 7, it
should depend only on whether GRASS was compiled with Large File
Support. In all GRASS versions, the limit with topology is at 2^31 -
1 (about 2 billion) features.
Markus M
> Pierre Roudier <pierre.roudier at gmail.com>
> Sent by: grass-dev-bounces at lists.osgeo.org
> 07/13/2011 03:05 AM
> To
> Markus Metz <markus.metz.giswork at googlemail.com>
> cc
> grass-dev <grass-dev at lists.osgeo.org>
> Subject
> Re: [GRASS-dev] Segmentation fault using v.in.lidar
> Thanks for the quick answer Markus,
> That would be a nice feature to add though. A lot of the LAS files are
> coming "tiled", and it'd be nice to be able to do something like:
> v.in.lidar in=*.las out=test_input_lidar -trb
> or
> v.in.lidar in=zone_32_*.las out=test_input_lidar -trb
> to import a special subset of LAS files.
> I've very few coding abilities, so this is just meant as another line
> on the wishlist ;)
> Thanks heaps for your work on *.in.lidar, it is working well otherwise,
> Pierre
> 2011/7/13 Markus Metz <markus.metz.giswork at googlemail.com>:
> > On Wed, Jul 13, 2011 at 2:08 AM, Pierre Roudier
> > <pierre.roudier at gmail.com> wrote:
> >> Hi,
> >> I've been trying to use v.in.lidar. It yields good results on one LAS
> >> file, but I get a segfault when trying it on several files:
> >>> v.in.lidar in=BD32_1610.las,BD32_1611.las out=test_input_lidar -trb
> >> Segmentation fault
> >>> v.in.lidar in=BD32_161*.las out=test_input_lidar -trb
> >> Segmentation fault
> >> Am I missing something, or is it a bug?
> > v.in.lidar takes only one input file at a time.
> > Markus M
> Scientist
> Landcare Research, New Zealand
> grass-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-dev
