[GRASS-dev] Segmentation fault using v.in.lidar
Markus Metz markus.metz.giswork at googlemail.com
Thu Jul 14 03:01:56 EDT 2011
On Thu, Jul 14, 2011 at 1:06 AM, Pierre Roudier
<pierre.roudier at gmail.com> wrote:
> Doug, Markus,
> Thanks for the interesting discussion,
>> In the short term, use the las2las command from liblas.org  to merge your .las files into a single las file and then process the one file.
> Yes at the moment, my workflow is:
> ls ID_*.las > las_list.txt
> lasmerge -i las_list.txt -o out.las
> v.in.lidar in=out.las out=lidar -trb
> Works very well. I was just wondering how difficult it would be to use
> wildcards directly in the input=... option. Obviously it requires some
> significant amount of work.
...only if wildcard support is to be included in v.in.lidar. Your
example above is only three short lines. Put them in a little script
with one input option las_files and one output option vector, that's
it.
>> You will have to watch out for the 4 billion point limit that is currently in the LAS file format, but for most folks that's not an issue.
> Indeed, not an issue for me (unfortunately!),
>> In all GRASS versions, the limit with topology is at  2^31 -
>> 1 (about 2 billion) features.
> I usually never build the topology of my LiDAR point clouds. Should I do it?
No, only if needed, i.e. if you want to process the imported point
clouds with a module that needs topology.
Markus M
>> Pierre Roudier <pierre.roudier at gmail.com>
>> Sent by: grass-dev-bounces at lists.osgeo.org
>> 07/13/2011 03:05 AM
>> To
>> Markus Metz <markus.metz.giswork at googlemail.com>
>> cc
>> grass-dev <grass-dev at lists.osgeo.org>
>> Subject
>> Re: [GRASS-dev] Segmentation fault using v.in.lidar
>> Thanks for the quick answer Markus,
>> That would be a nice feature to add though. A lot of the LAS files are
>> coming "tiled", and it'd be nice to be able to do something like:
>> v.in.lidar in=*.las out=test_input_lidar -trb
>> or
>> v.in.lidar in=zone_32_*.las out=test_input_lidar -trb
>> to import a special subset of LAS files.
>> I've very few coding abilities, so this is just meant as another line
>> on the wishlist ;)
>> Thanks heaps for your work on *.in.lidar, it is working well otherwise,
>> Pierre
>> 2011/7/13 Markus Metz <markus.metz.giswork at googlemail.com>:
>> > On Wed, Jul 13, 2011 at 2:08 AM, Pierre Roudier
>> >> Hi,
>> >> I've been trying to use v.in.lidar. It yields good results on one LAS
>> >> file, but I get a segfault when trying it on several files:
>> >>> v.in.lidar in=BD32_1610.las,BD32_1611.las out=test_input_lidar -trb
>> >> Segmentation fault
>> >>> v.in.lidar in=BD32_161*.las out=test_input_lidar -trb
>> >> Segmentation fault
>> >> Am I missing something, or is it a bug?
>> > v.in.lidar takes only one input file at a time.
>> > Markus M
>> Scientist
>> Landcare Research, New Zealand
>> grass-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
> Scientist
