[GRASS-dev] Re: [GRASS GIS] #1409: wxGUI command console does not parse correctly "help" and first parameter
GRASS GIS trac at osgeo.org
Tue Jul 26 11:52:10 EDT 2011
 Reporter:  philippbs  |       Owner:  grass-dev@…
     Type:  defect     |      Status:  new
 Priority:  normal     |   Milestone:  6.4.2
Component:  wxGUI      |     Version:  svn-releasebranch64
 Keywords:             |    Platform:  All
      Cpu:  x86-64     |
Comment(by cmbarton):
 The command console is not designed to support the in-terminal help.
 Instead, pressing the <tab> key will show the command syntax, much like
 typing help. There needs to be a better error trap when "help" is typed to
 inform the user of that.
 There is also a full help manual as a tab in every command module.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1409#comment:2>
