[GRASS-dev] Re: [GRASS GIS] #1409: wxGUI command console does not
parse correctly "help" and first parameter
trac at osgeo.org
Tue Jul 26 11:58:16 EDT 2011
#1409: wxGUI command console does not parse correctly "help" and first parameter
Reporter: philippbs | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.2
Component: wxGUI | Version: svn-releasebranch64
Keywords: | Platform: All
Cpu: x86-64 |
Comment(by cmbarton):
I stand corrected. If you type the command, followed by "help", the
standard terminal help will print to the console output window.
This works for all commands EXCEPT d.* commands. When I type a d.*
command, followed by "help", I get an error "Error: rendering failed" and
all subsequent attempts to display a map in the window fail (with the same
error). It acts like I've switched to the Cairo driver, but the display
says it is still on the PNG driver.
Some weird bug here.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1409#comment:3>
