[GRASS-dev] odd configure error on MacOS X
William Kyngesburye
woklist at kyngchaos.com
Fri Jul 29 09:19:11 EDT 2011
On Jul 29, 2011, at 3:41 AM, Dylan Beaudette wrote:
> It seems more complicated that I thought. After fixing the includes,
> to use the KingChaos Frameworks, recompiling results in:
> In file included from Graph.c:19:
> /Library/Frameworks/cairo.framework/unix/include/cairo/cairo-svg.h:79:3:
> error: #error Cairo was not compiled with support for the svg backend
> make: *** [OBJ.i386-apple-darwin9.8.0/Graph.o] Error 1
> Can SVG be disabled somehow?
> Dylan
Odd, my cairo framework svg support. cairo-features.h has:
#define CAIRO_HAS_SVG_SURFACE 1
FYI, I configure GRASS for my cairo framework with (note the *2* include dirs):
--with-cairo --with-cairo-includes="/Library/Frameworks/cairo.framework/unix/include/cairo /Library/Frameworks/cairo.framework/unix/include" --with-cairo-libs=/Library/Frameworks/cairo.framework/unix/lib --with-cairo-ldflags="-lcairo" \
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
