[GRASS-dev] Weekly reports #2 wxNviz
Martin Landa
landa.martin at gmail.com
Fri Jun 10 11:59:57 EDT 2011
2011/6/10 Helena Mitasova <hmitaso at ncsu.edu>:
> I just tested it and you are probably trying to start it with vector data generated in grass64,
> if you want to use vector data in grass7 you need to rebuild the topology.
> I just tried the latest updates - it works fine for me and it has a lot of cool updates.
> It crashed when I tried to add vector layer in grass64 format.
it should not crash, try digitizer, you should get a dialog for
rebuilding topology when opening vector for editing.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
