[GRASS-dev] Principle G3D library question
Hamish
hamish_b at yahoo.com
Sat Jun 18 03:58:08 EDT 2011
[r3.in.ascii]
readHeaderString()
while (fgetc(fp) != '\n');
probably it should use G_getl2(), which also accepts DOS and MacOS9 newlines?
> version:
> order:
once formally decided, we should modify the 6.x versions to deal with the
extra header instructions, and continue on (with a message?) if it matches
grass6's format, otherwise fatal_error out with a reasonable error message.
ASCII is an acronym of a named entity, and should remain uppercased.
> Note that unit tests for r3.in.ascii are implemented in the
> <em>test.r3.out.ascii.sh</em> script located in the r3.out.ascii directory.
if many/most modules will eventually get test scripts, is it worth
mentioning that in the help page? maybe <!-- commented out --> so only
developers see it?
I think is it enough to describe in the grass7 help page how
to make a grass6-compatible G3D output file, probably with an
example. A flag for that could be overkill.
btw, I believe the "AV" responsible for parts of the G3D code is Alfonso Vitti.
Hamish
