[GRASS-dev] Re: [GRASS-SVN] r46717 - grass/branches/releasebranch_6_4/scripts/v.build.all
Hamish hamish_b at yahoo.com
Tue Jun 28 05:45:20 EDT 2011
Markus wrote:
> So you suggest to replace
> CMD="v.build map=${VECT}@${MAPSET}"
> with e.g.
> CMD="v.build map='$VECT@$MAPSET'"
that won't work as we need the variables expanded for later.
perhaps just leave them out (no change from current situation)
-    CMD="v.build map=${VECT}@${MAPSET}"
+    CMD="v.build map=$VECT@$MAPSET"
as vector names and mapset(?) names should be shell-safe.
if it became
+    CMD="v.build map=\"$VECT@$MAPSET\""
then it would also need to replace
-    $CMD
+    eval $CMD
Actually, I'm not really sure why that $CMD + g.message is needed
at all. Maybe as a g.message -d debug or verbose message, or is
it there for instructive purposes..?
shrug,
Hamish
