[GRASS-dev] Re: [GRASS-SVN] r46717 -
grass/branches/releasebranch_6_4/scripts/v.build.all
Markus Metz
markus.metz.giswork at googlemail.com
Tue Jun 28 04:47:42 EDT 2011
On Tue, Jun 28, 2011 at 10:32 AM, Hamish <hamish_b at yahoo.com> wrote:
>> >> > CMD="v.build map=${VECT}@${MAPSET}"
> Hamish:
>> > ps- those curly brackets do nothing..
> Markus M:
>> also no harm
> yes and no-
> sure it's a minor issue, but they help propagate
> the myth that curly brackets can be used to safely
> quote shell variables, which is harmful & also has
> the consequence of folks looking right past them
> when they try to debug a script with e.g. spaces in
> the filename variable. Mostly I bring this up
> because I have grown tired of fixing them, and hope
> that illuminating the problem can make it go away.
> fwiw, all module shell scripts have been audited
> and to my knowledge are now all quoted safely- so
> these thoughts are directed at newly committed code.
So you suggest to replace
with e.g.
CMD="v.build map='$VECT@$MAPSET'"
Markus M
