[GRASS-dev] SEARCH_PATH: current mapset name laundering
Glynn Clements
glynn at gclements.plus.com
Tue May 3 15:13:32 EDT 2011
Markus Neteler wrote:
> > Realistically, I think that the current mapset must always be at the
> > head of the search path. Allowing it to be otherwise will be
> > error-prone.
> > Otherwise, we have to fix existing scripts to explicitly add the
> > current mapset to any temporary map names. It's much simpler to change
> > the library to match existing practice.
> Definitely - I'd vote for a library update.
Try r46173.
