[GRASS-dev] SEARCH_PATH: current mapset name laundering
Markus Neteler
neteler at osgeo.org
Tue May 3 16:35:11 EDT 2011
On Tue, May 3, 2011 at 9:13 PM, Glynn Clements <glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> > Realistically, I think that the current mapset must always be at the
>> > head of the search path. Allowing it to be otherwise will be
>> > error-prone.
>> > Otherwise, we have to fix existing scripts to explicitly add the
>> > current mapset to any temporary map names. It's much simpler to change
>> > the library to match existing practice.
>> Definitely - I'd vote for a library update.
> Try r46173.
Thanks.
Attached the backport to GRASS 6 for a review.
Markus
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20110503/d711f032/mapset_nme.bin
