[GRASS-dev] compilation of wx.psmap in GRASS 6.4.2
manuel.martin
manuel.martin at orleans.inra.fr
Thu May 5 09:00:32 EDT 2011
Hello all,
I tried to install the very welcomed WxGui for ps.map but it failed and
I'm not sure how to fix it, although I think it should not be too
complicated. I am running GRASS 6.4.2 from Ubuntu 10.10.
Thank you in advance, Manuel
/from the wxGUI Command prompt/ I get a :
(Thu May 5 14:49:25 2011)
g.extension.py -s svnurl=https://svn.osgeo.org/grass/grass-addons
extension=wx.psmap
Fetching 'wx.psmap' from GRASS-Addons SVN (be patient)...
A wx.psmap/xml
A wx.psmap/xml/menudata_psmap.xml
A wx.psmap/images
A wx.psmap/images/scalebar-simple.png
A wx.psmap/images/Makefile
A wx.psmap/images/scalebar-fancy.png
A wx.psmap/docs
A wx.psmap/docs/wxGUI.PsMap.html
A wx.psmap/docs/Makefile
A wx.psmap/gui_modules
A wx.psmap/gui_modules/psmap.py
A wx.psmap/gui_modules/psmap_dialogs.py
A wx.psmap/Makefile
A wx.psmap/README
Checked out revision 46198.
Compiling 'wx.psmap'...
Makefile:5: /usr/lib/grass64/include/Make/Dir.make: No such
file or directory
Makefile:6: /usr/lib/grass64/include/Make/Python.make: No
such file or directory
make: *** No rule to make target
`/usr/lib/grass64/include/Make/Python.make'. Stop.
ERROR: Compilation failed, sorry. Please check above error messages.
(Thu May 5 14:49:38 2011) Command finished (12 sec)
INRA - InfoSol
Centre de recherche d'Orléans
2163 Avenue de la Pomme de Pin
CS 40001 ARDON
45075 ORLEANS Cedex 2
tel : (33) (0)2 38 41 48 21
fax : (33) (0)2 38 41 78 69
http://www.gissol.fr
http://bdat.orleans.inra.fr
----0----0------------------
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20110505/20c07249/attachment.html
