[GRASS-dev] compilation of wx.psmap in GRASS 6.4.2
Markus Neteler
neteler at osgeo.org
Thu May 5 13:19:18 EDT 2011
On Thu, May 5, 2011 at 3:00 PM, manuel.martin
<manuel.martin at orleans.inra.fr> wrote:
> Hello all,
> I tried to install the very welcomed WxGui for ps.map but it failed and I'm
> not sure how to fix it, although I think it should not be too complicated. I
> am running GRASS 6.4.2 from Ubuntu 10.10.
Just to be sure: GRASS 6.4.2 hasn't been released yet. Do they
package GRASS 6.4.svn (which would be good in this case)?
> Thank you in advance, Manuel
> from the wxGUI Command prompt I get a :
> (Thu May 5 14:49:25
> 2011)
> g.extension.py -s svnurl=https://svn.osgeo.org/grass/grass-addons
> extension=wx.psmap
> Fetching 'wx.psmap' from GRASS-Addons SVN (be patient)...
> A wx.psmap/xml
> A wx.psmap/xml/menudata_psmap.xml
> A wx.psmap/images
> A wx.psmap/images/scalebar-simple.png
> A wx.psmap/images/Makefile
> A wx.psmap/images/scalebar-fancy.png
> A wx.psmap/docs
> A wx.psmap/docs/wxGUI.PsMap.html
> A wx.psmap/docs/Makefile
> A wx.psmap/gui_modules
> A wx.psmap/gui_modules/psmap.py
> A wx.psmap/gui_modules/psmap_dialogs.py
> A wx.psmap/Makefile
> A wx.psmap/README
> Checked out revision 46198.
> Compiling 'wx.psmap'...
> Makefile:5: /usr/lib/grass64/include/Make/Dir.make: No such
> file or directory
This indicates that the "grass-dev" package is missing on your
computer. Please report if that helps.
Markus
