[GRASS-dev] compilation of wx.psmap in GRASS 6.4.2
manuel.martin
manuel.martin at orleans.inra.fr
Fri May 6 10:20:32 EDT 2011
On 05/05/2011 07:19 PM, Markus Neteler wrote:
> On Thu, May 5, 2011 at 3:00 PM, manuel.martin
> <manuel.martin at orleans.inra.fr> wrote:
>> Hello all,
>> I tried to install the very welcomed WxGui for ps.map but it failed and I'm
>> not sure how to fix it, although I think it should not be too complicated. I
>> am running GRASS 6.4.2 from Ubuntu 10.10.
> Just to be sure: GRASS 6.4.2 hasn't been released yet. Do they
> package GRASS 6.4.svn (which would be good in this case)?
Yes it is GRASS 6.4.2svn (2011) which I am using right now. the rest of
my comments below.
> g.version -c
>> Thank you in advance, Manuel
>> from the wxGUI Command prompt I get a :
>> (Thu May 5 14:49:25
>> 2011)
>> g.extension.py -s svnurl=https://svn.osgeo.org/grass/grass-addons
>> extension=wx.psmap
>> Fetching 'wx.psmap' from GRASS-Addons SVN (be patient)...
>> A wx.psmap/xml
>> A wx.psmap/xml/menudata_psmap.xml
>> A wx.psmap/images
>> A wx.psmap/images/scalebar-simple.png
>> A wx.psmap/images/Makefile
>> A wx.psmap/images/scalebar-fancy.png
>> A wx.psmap/docs
>> A wx.psmap/docs/wxGUI.PsMap.html
>> A wx.psmap/docs/Makefile
>> A wx.psmap/gui_modules
>> A wx.psmap/gui_modules/psmap.py
>> A wx.psmap/gui_modules/psmap_dialogs.py
>> A wx.psmap/Makefile
>> A wx.psmap/README
>> Checked out revision 46198.
>> Compiling 'wx.psmap'...
>> Makefile:5: /usr/lib/grass64/include/Make/Dir.make: No such
>> file or directory
> This indicates that the "grass-dev" package is missing on your
> computer. Please report if that helps.
The thing is that the only grass-dev package available for now with
ubuntu 10.10 depends on GRASS (= 6.4.0~rc6+42329-1) which I am not
using right now. Thus I failed installing grass-dev.
Should I downgrade to GRASS (= 6.4.0~rc6+42329-1), or where may I get a
grass-dev package compatible with GRASS 6.4.2svn?
Thanks a lot, Manuel
> Markus
INRA - InfoSol
Centre de recherche d'Orléans
2163 Avenue de la Pomme de Pin
CS 40001 ARDON
45075 ORLEANS Cedex 2
tel : (33) (0)2 38 41 48 21
fax : (33) (0)2 38 41 78 69
http://www.gissol.fr
http://bdat.orleans.inra.fr
----0----0------------------
