[GRASS-dev] Re: [GRASS GIS] #390: r.viewshed precision bug
trac at osgeo.org
Fri May 6 04:06:02 EDT 2011
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.2
Component: Raster | Version: svn-develbranch6
Keywords: r.viewshed | Platform: All
Cpu: All |
Comment(by mmetz):
Replying to [comment:4 hamish]:
> > The precision bug is hopefully fixed in r46199.
> excellent...! with that fixed, how close do you think it is to
migrating r.viewshed out of addons and into the main source tree? or is
there still work to do?
> if it's ready, does it mean r.los is now redundant, or does r.los have
some purpose/feature worth saving?
Maybe the r.los input option patt_map which is used as a mask, but from
reading the r.los manual, the difference to setting a MASK is not clear to
me.
For GRASS 7, we are free to change module options, for GRASS 6, this
patt_map option could be added for compatibility reasons, but the only
effect would then be to print out a warning that a MASK should be used
instead of patt_map=mask_map?
Ticket URL: <https://trac.osgeo.org/grass/ticket/390#comment:6>
