[GRASS-dev] Re: [GRASS GIS] #390: r.viewshed precision bug
trac at osgeo.org
Fri May 6 05:09:18 EDT 2011
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.2
Component: Raster | Version: svn-develbranch6
Keywords: r.viewshed | Platform: All
Cpu: All |
Comment(by hamish):
note compiler warning: (x3)
include/grass/iostream/replacementHeapBlock.h:146: warning: 'str' may be
used uninitialized in this function
spearfish test:
g.region -d
r.surf.volcano output=gauss method=gaussian sigma=1
d.where
r.viewshed in=gauss out=gauss.shed coord=597900,4920840 max_dist=7500 --o
d.histogram gauss.shed
seems to keep -1 as invisibile not NULL ????? fix:
r.null gauss.shed setnull=-1
r.colors gauss.shed color=bcyr
d.redraw
# 180deg is just @ viewing cell, so for good colors we also need: (PITA,
so maybe we could build that into the module)
r.null gauss.shed setnull=180
d.redraw
echo "597900,4920840" | v.in.ascii out=view_pt fs=,
nviz gauss color=gauss.shed points=view_pt
coord, -r desc: lat/lon -> easting/northing
(seems to use current e,n LOCATION coords already..)
drop the -r flag now that debugging stage is ending?
tgt_elev=: how is that used if a target coord is never defined?
any interesting coverage/patch map functionality from r.cva which would
be interesting to clean-room reimpliement?
timings on my trusty old P4:
G:65> time r.viewshed in=elevation.dem out=elev.shed coord=597900,4920840
max_dist=7500 --o
real 0m3.898s
user 0m3.768s
sys 0m0.084s
G65> time r.los in=elevation.dem out=elev.shed coord=597900,4920840
max_dist=7500
real 0m4.156s
user 0m4.004s
sys 0m0.108s
G65> g.region rast=elevation.10m
G65> time r.viewshed in=elevation.10m out=elev.shed coord=597900,4920840
max_dist=7500 --o
real 0m42.330s
user 0m40.791s
sys 0m0.532s
G65> time r.los in=elevation.10m out=elev.shed coord=597900,4920840
max_dist=7500 --o
real (finsihed in about 20 minutes)
indeed it seems to scale a bit better than r.los ... :-)
> For GRASS 7, we are free to change module options, for GRASS 6, this
patt_map
> option could be added for compatibility reasons, but the only effect
would
> then be to print out a warning that a MASK should be used instead of
> patt_map=mask_map?
I wasn't thinking to make this as r.los2; as it is a totally diff't code
base I'd add it named as r.viewshed, and drop r.los in grass7.
but maybe it is prefered to keep the r.los name? if so then at least in
GRASS 6.x it would be fine to have the option as "This does nothing and is
kept for backwards compatibility reasons." and the warning as you
describe.
? since r.los is so useless at modern region array sizes, maybe we
should..
alternately, we could add r.viewshed in 6.x with a wrapper script for the
old r.los name, like r.cats -> r.category.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/390#comment:7>
