[GRASS-dev] Re: [GRASS GIS] #390: r.viewshed precision bug
trac at osgeo.org
Fri May 6 05:25:55 EDT 2011
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.2
Component: Raster | Version: svn-develbranch6
Keywords: r.viewshed | Platform: All
Cpu: All |
Comment(by hamish):
Hamish:
> tgt_elev=: how is that used if a target coord is never defined?
never mind, I get it.
> alternately, we could add r.viewshed in 6.x with a
> wrapper script for the old r.los name, like r.cats ->
> r.category.
I'm liking this idea. [+ compatibility option for gr6]
> any interesting coverage/patch map functionality
> from r.cva which would be interesting to clean-room
> reimplemented?
fyi, r.cva:
r.cva draws heavily on the code for r.los, which was written by
Kewan Q. Khawaja, Intelligent Engineering Systems Laboratory, M.I.T.
PURPOSE
1) Perform cumulative viewshed (CVA) analysis.
OPTIONS
1) Record the number of cells visible from:
all every map cell;
systematic a systematic sample of map cells;
random a random sample of map cells;
sites a list of sites.
2) Record how often each cell in the map is visible from:
all every map cell;
3) Random sampling may occur with or without replacement.
4) All types of sampling may be subject to binary masks such that:
i) Not all possible destination cells (cells to be `looked at')
are of interest;
ii) Not all possible viewpoints are of interest.
5) It is possible to specify the height of the observer.
6) It is possible to specify the height of the target object
above ground.
NOTE
r.cva includes fixes for two bugs in the current version of r.los.
These are that the observer elevation is cast to an integer, and that
the patt_map does not effect the viewpoint and its immediately
neighbouring cells
module options:
input: elev raster
target_mask: binary raster map for target cells
viewpt_mask: binary raster map for viewpoints
sites: vector points layer
output: raster
obs_elev: ...
target_elev: ...
max_dist: ...
seed: for rand num gen
sample: sampling frequency as a percentage of cells (default 10.0)
type: {all,systematic,random,sites}
all cells; systematic sample; random sample; sites map
-f calculate the `visibility from' rather than `viewsheds of'
-m differentiate masked cells from data value zero
-n treat sample size as no. of cells
-r allow replacement during random sampling
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/390#comment:8>
