[GRASS-dev] Re: [GRASS GIS] #1357: v.net.salesman and
forward/backward movement cost
trac at osgeo.org
Wed May 11 03:24:22 EDT 2011
#1357: v.net.salesman and forward/backward movement cost
Reporter: lluis | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: unspecified
Keywords: v.net.salesman,network, vector, network analysis, travel cost, forward, backward | Platform: Linux
Cpu: x86-64 |
Changes (by Lluis):
* cc: Lluis (added)
Comment:
Great! It seems to work properly. I've been doing some tests using open
street map cartography, and it seems that I'm getting valid results. I
will try to do more tests but it seems to work correctly.
Thanks a lot for your work and effort, Moritz!
Lluís
Replying to [comment:2 mlennert]:
> Replying to [comment:1 mmetz]:
> > Implemented in grass 7, r46229, please test!
> Here are the results of an abritrary test on in the NC demo dataset:
> [http://geog-pc40.ulb.ac.be/grass/equalcost.png equal cost in both
directions]
> [http://geog-pc40.ulb.ac.be/grass/diffcost.png different cost in each
direction for one way streets]
> I'll attach the script with the relevant commands I used.
> At first view, the results seem to be coherent, but probably need more
detailed testing.
> Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1357#comment:3>
