[GRASS-dev] Re: [GRASS GIS] #854: g.extension does not work on a
Mac (probably not on Windows either
trac at osgeo.org
Fri May 13 22:07:13 EDT 2011
#854: g.extension does not work on a Mac (probably not on Windows either
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.2
Component: Installation | Version: 6.4.1 RCs
Keywords: g.extension, addons | Platform: All
Cpu: All |
Comment(by glynn):
Replying to [comment:13 kyngchaos]:
> I think I had originally done it your way in the top level makefile, but
glynn changed it. Or he changed something similar elsewhere, and I
changed this case to match.
Note that I hardly ever touch 6.x. Most of the problems stem from trying
to back-port isolated parts of 7.x to 6.x, when the changes to the build
system are highly inter-dependent. But back-porting the entire build
system would run into problems with "unusual" modules (most of which have
been eliminated from 7.x).
BTW: one of the original reasons for not keeping the 6.x build system in
sync was that the 7.x build system absolutely requires GNU make 3.81,
which wasn't universally available at the time (e.g. MacOSX was still on
3.79). I don't think that's an issue any more.
Ticket URL: <http://trac.osgeo.org/grass/ticket/854#comment:15>
