[GRASS-dev] Re: [GRASS GIS] #1178: WinGrass: g.extension - problem
with path to $GISBASE
trac at osgeo.org
Mon May 16 15:01:36 EDT 2011
#1178: WinGrass: g.extension - problem with path to $GISBASE
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.1
Component: Installation | Version: svn-releasebranch64
Keywords: wingrass, g.extension, path, installation, addons | Platform: MSWindows Vista
Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:30 neteler]:
> More fixes have been applied in SVN, please retry.
tested with WinGRASS-6.4.SVN-r46317-1-Setup.exe
GRASS 6.4> g.extension extension=r.stream.order
which: wget: unknown command
WARNUNG: GRASS_ADDON_PATH is not defined, installing to ~/.grass6/addons/
Fetching <r.stream.order> from GRASS-Addons SVN (be patient)...
A r.stream.order\main.c
A r.stream.order\description.html
A r.stream.order\global.h
A r.stream.order\io.c
A r.stream.order\order.c
A r.stream.order\Makefile
Checked out revision 46320.
Compiling <r.stream.order>...
makefile:12: c:/Program: No such file or directory
makefile:12: Files/GRASS: No such file or directory
makefile:12: 6.4.SVN/include/Make/Module.make: No such file or directory
make: *** No rule to make target `6.4.SVN/include/Make/Module.make'.
Stop.
FEHLER: Compilation failed, sorry. Please check above error messages.
rm: cannot remove directory
`C:\\gisdata\\grassdata/nc_spm_08/user1/.tmp/4928.0/r.stream.order':
Permission denied
there's still the whitespace-issue.
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1178#comment:31>
