[GRASS-dev] Re: [GRASS GIS] #1178: WinGrass: g.extension - problem
with path to $GISBASE
trac at osgeo.org
Mon May 16 15:54:02 EDT 2011
#1178: WinGrass: g.extension - problem with path to $GISBASE
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.1
Component: Installation | Version: svn-releasebranch64
Keywords: wingrass, g.extension, path, installation, addons | Platform: MSWindows Vista
Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:31 hellik]:
> there's still the whitespace-issue.
if I set GISBASE manually in g.extension to
GISBASE=C:/PROGRA~1/GRASS6~1.SVN
GRASS 6.4> g.extension extension=r.stream.order
which: wget: unknown command
WARNUNG: GRASS_ADDON_PATH is not defined, installing to ~/.grass6/addons/
Fetching <r.stream.order> from GRASS-Addons SVN (be patient)...
A r.stream.order\main.c
A r.stream.order\description.html
A r.stream.order\global.h
A r.stream.order\io.c
A r.stream.order\order.c
A r.stream.order\Makefile
Checked out revision 46320.
Compiling <r.stream.order>...
C:/PROGRA~1/GRASS6~1.SVN/include/Make/Module.make:25: warning: overriding
commands for target `install'
C:/PROGRA~1/GRASS6~1.SVN/include/Make/Rules.make:90: warning: ignoring old
mkdir -p
C:\gisdata\grassdata/nc_spm_08/user1/.tmp/5376.0/dist/include/grass
mkdir -p C:\gisdata\grassdata/nc_spm_08/user1/.tmp/5376.0/dist/bin
mkdir -p C:\gisdata\grassdata/nc_spm_08/user1/.tmp/5376.0/dist/etc
mkdir -p C:\gisdata\grassdata/nc_spm_08/user1/.tmp/5376.0/dist/driver
mkdir -p C:\gisdata\grassdata/nc_spm_08/user1/.tmp/5376.0/dist/driver/db
mkdir -p C:\gisdata\grassdata/nc_spm_08/user1/.tmp/5376.0/dist/fonts
test -d OBJ.i686-pc-mingw32 || mkdir -p OBJ.i686-pc-mingw32
gcc -IC:/PROGRA~1/GRASS6~1.SVN/include
-I/home/syringia/.grass6/addons/include
-IC:\gisdata\grassdata/nc_spm_08/user1/.tmp/ 5376.0/dist/include
-I/c/OSGeo4W/include -g -O2 -I/c/OSGeo4W/include -I/c/OSGeo4W/include
-I/c/OSGeo4W/include -DPACKAG E=\""grassmods"\"
-IC:/PROGRA~1/GRASS6~1.SVN/include -I/home/syringia/.grass6/addons/include
-IC:\gisdata\grassdata/nc_spm _08/user1/.tmp/5376.0/dist/include
-o OBJ.i686-pc-mingw32/io.o -c io.c
gcc.exe: installation problem, cannot exec `cc1': No such file or
directory
make: *** [OBJ.i686-pc-mingw32/io.o] Error 1
FEHLER: Compilation failed, sorry. Please check above error messages.
rm: cannot remove directory
`C:\\gisdata\\grassdata/nc_spm_08/user1/.tmp/5376.0/r.stream.order':
Permission denied
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1178#comment:32>
