[GRASS-dev] Re: [GRASS-user] LiDAR LAS import
Hamish
hamish_b at yahoo.com
Wed May 25 18:38:12 EDT 2011
MMetz:
> > I discovered a bug in v.in.ascii: from a point file with |
> > as field separator like
> > 1|2|3||5|6
> > only the first 3 columns will be imported because column 4
> > is empty which means that columns 5 and 6 are skipped.
Hamish:
> roughly/quickly:
> echo "1|2|3||5|6" | v.in.ascii in=- out=gaptest
> v.db.select gaptest
> GRASS 6.4.0+42329 bug
> GRASS 6.5.svn45825M no bug
> GRASS 7.0.svn45737M no bug
> I'll try with latest svn in the morning.
latest svn builds, all branches: no bug with v.in.ascii.
I did not test v.in.ogr for it yet.
> perhaps this was fixed by the v.in.ascii last-row-is-empty
> bugfix some months ago?
(ticket #198)
Hamish
