[GRASS-dev] Re: [GRASS GIS] #1196: v.krige.py fails with
ImportError: No module named vkrige
trac at osgeo.org
Mon May 30 03:45:13 EDT 2011
#1196: v.krige.py fails with ImportError: No module named vkrige
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.5.0
Component: Vector | Version: svn-develbranch6
Keywords: v.krige | Platform: Linux
Cpu: x86-64 |
Changes (by hamish):
* keywords: => v.krige
Comment:
apparently it needs to be started with:
v.krige.py --ui
to forcibly launch the parser. probably an easy fix for that, but I'm not
sure of the exact incantation.
(also it would be good to tweak the Makefile to install the module to
$GISBASE/scripts/ ''without'' the .py extension)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1196#comment:1>
