[GRASS-dev] Re: [GRASS GIS] #958: v.krige does not run in GRASS 7
trac at osgeo.org
Mon May 30 04:03:58 EDT 2011
Reporter: cmbarton | Owner: aghisla
Type: defect | Status: assigned
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Keywords: v.krige | Platform: All
Cpu: All |
Changes (by hamish):
* cc: aghisla (removed)
* cc: grass-dev@… (added)
* keywords: krige => v.krige
Comment:
seems to work for me now (almost), bug resolved?
the list of dependencies takes a few iterations to get past, but after
following the R+GRASS install instructions on the GRASS wiki, and after
that is working
install.packages("put-pkg-name-here")
in an R session for all the ones v.krige complained about missing.
As commented earlier in the ticket, probably explicitly listing them in
the v.krige man page, and as a footer section in the GRASS wiki's "R" page
will help folks get through them quickly. I wonder how we could automate
that more?
I do get one error now when I run it in grass7:
Checking rgeos availability as gpclib substitute:
TRUE
Loading required package: automap
GSelect: invalid item: descriptor 'lower' requires a 'unicode' object but
received a 'str
We've seen that before in the main wx.gui, and ISTR it's an easy fix. I'm
using `LANG=C`.
thanks,
Hamish
ps- trac-tip: if you comment or change a ticket you're automatically added
to the cc-list. If you take ownership you have to then manually add the
grass-dev ML to the cc-list.
pps- do you lose anything by using the free-for-all-use rgeos cran package
versus the first-tried free-for-commercial-use gpclib cran package? aka
why not make rgeos the default?
Ticket URL: <https://trac.osgeo.org/grass/ticket/958#comment:10>
