[GRASS-dev] Re: [GRASS GIS] #1280: problem about the output of
g.parser
trac at osgeo.org
Tue May 31 12:36:10 EDT 2011
#1280: problem about the output of g.parser
Reporter: met | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.1
Component: Default | Version: 6.4.1 RCs
Keywords: wingrass, g.parser | Platform: MSWindows XP
Cpu: All |
Changes (by benducke):
* priority: minor => major
* cpu: OSX/Intel => All
Comment:
This bug also creates havoc for shell scripts running under Windows. E.g.
I have a script that takes a file name as an output (option defined with:
"gisprompt: new_file,file,output"). If the user inputs something like
this: "C:\Documents\Output.tif" as option value, then g.parser mangles it
to: "C:DocumentsOutput.tif". I have tested this on Windows XP with GRASS
6.4.0RC6. But given that this ticket is still open, I assume that the bug
is still around, too? If so, it needs to be fixed, as it could put a
number of scripts out-of-order under Windows.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1280#comment:2>
