Glynn wrote: > If g.html2man is required in order to build add-ons, then it should be > installed as part of the GRASS build process, and subsequently > referenced via $(GISBASE), as is done in 7.0. this is the approach taken in r49126 and r49127. hopefully everything works now, and is kosher ta boot. Hamish
