[GRASS-dev] Re: [GRASS-SVN] r49122 - grass/branches/develbranch_6/include/Make
Martin Landa landa.martin at gmail.com
Tue Nov 8 12:16:03 EST 2011
2011/11/8 Hamish <hamish_b at yahoo.com>:
> Glynn wrote:
>> If g.html2man is required in order to build add-ons, then it should be
>> installed as part of the GRASS build process, and subsequently
>> referenced via $(GISBASE), as is done in 7.0.
> this is the approach taken in r49126 and r49127.
> hopefully everything works now, and is kosher ta boot.
not at all
g.extension ext=i.points.auto
mkdir -p /home/martin/grassdata/zod2011/landamar1/.tmp/pierre/28801.0/dist.i686/man/man1
GRASS_PERL=/usr/bin/perl VERSION_NUMBER=6.5.svn sh
/home/martin/grassdata/zod2011/landamar1/.tmp/pierre/28801.0/dist.i686/tools/g.html2man
/home/martin/grassdata/zod2011/landamar1/.tmp/pierre/28801.0/dist.i686/docs/html/i.points.auto.html
/home/martin/grassdata/zod2011/landamar1/.tmp/pierre/28801.0/dist.i686/man/man1/i.points.auto.1
1
sh: 0: Can't open
make[2]: *** [/home/martin/grassdata/zod2011/landamar1/.tmp/pierre/28801.0/dist.i686/man/man1/i.points.auto.1]
Error 127
make[2]: Leaving directory
`/home/martin/grassdata/zod2011/landamar1/.tmp/pierre/28801.0/i.points.auto'
make[1]: *** [mancmd] Error 2
make[1]: Leaving directory
make: *** [cmd] Error 2
ERROR: Compilation failed, sorry. Please check above error messages.
g.extension still *broken*. Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
