[GRASS-dev] Re: [GRASS-SVN] r49204 - grass/trunk/vector/v.info
Martin Landa landa.martin at gmail.com
Mon Nov 14 03:40:59 EST 2011
shrug, `-g` is mainly used for shell script output, I think it would
be better update `r.info` and `v.info` to follow this logic, g.region
is an exception. You are going to the opposite direction!
2011/11/14  <svn_grass at osgeo.org>:
> Author: hamish
> Date: 2011-11-13 22:49:25 -0800 (Sun, 13 Nov 2011)
> New Revision: 49204
> Modified:
>   grass/trunk/vector/v.info/parse.c
>   grass/trunk/vector/v.info/v.info.html
> Log:
> swap (ie restore) flags: -g is used throughout for map region info, same usage as g.region and r.info
> Modified: grass/trunk/vector/v.info/parse.c
> --- grass/trunk/vector/v.info/parse.c   2011-11-13 23:58:35 UTC (rev 49203)
> +++ grass/trunk/vector/v.info/parse.c   2011-11-14 06:49:25 UTC (rev 49204)
> @@ -30,19 +30,19 @@
>        _("Print types/names of table columns for specified layer instead of info and exit");
>     col_flag->guisection = _("Print");
> +    region_flag = G_define_flag();
> +    region_flag->key = 'g';
> +    region_flag->description = _("Print region info in shell script style");
> +    region_flag->guisection = _("Print");
>     shell_flag = G_define_flag();
> -    shell_flag->key = 'g';
> -    shell_flag->description = _("Print basic info in shell script style");
> +    shell_flag->key = 'e';
> +    shell_flag->description = _("Print extended metadata info in shell script style");
>     shell_flag->guisection = _("Print");
> -    region_flag = G_define_flag();
> -    region_flag->key = 'e';
> -    region_flag->description = _("Print also region info in shell script style");
> -    region_flag->guisection = _("Print");
>     topo_flag = G_define_flag();
>     topo_flag->key = 't';
> -    topo_flag->description = _("Print also topology info in shell script style");
> +    topo_flag->description = _("Print topology info in shell script style");
>     topo_flag->guisection = _("Print");
>     if (G_parser(argc, argv))
> Modified: grass/trunk/vector/v.info/v.info.html
> --- grass/trunk/vector/v.info/v.info.html       2011-11-13 23:58:35 UTC (rev 49203)
> +++ grass/trunk/vector/v.info/v.info.html       2011-11-14 06:49:25 UTC (rev 49204)
> @@ -116,7 +116,7 @@
>  </pre></div>
>  <div class="code"><pre>
> -v.info -e map=geology
> +v.info -g map=geology
>  north=318117.43741634
>  south=10875.82723209
> grass-commit mailing list
> grass-commit at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-commit
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
