[GRASS-dev] compiling error in db.select
Markus Neteler neteler at osgeo.org
Mon Nov 14 09:47:35 EST 2011
On Sat, Nov 12, 2011 at 12:10 AM, Hamish <hamish_b at yahoo.com> wrote:
> Michael wrote:
>> I just did an update and tried to compile trunk.
>> I got an error in db.select. Note that I did a
>> make distclean followed by an svn up before
>> configuring and compiling.
>> main.c: In function ‘main’:main.c:56: error:
>> ‘ERROR’ undeclared (first use in this
>> function)
> probably due to r49183
No - just "make distclean" - the common answer if compilation
fails... and a file cleanup was definitely needed there.
Markus
