[GRASS-dev] How can I cange or modify the GUI for watershed
analysis?
Sören Gebbert
soerengebbert at googlemail.com
Tue Nov 15 07:41:53 EST 2011
2011/11/15 Sandip Maity <sandip.stesalit at gmail.com>:
> Dear Soren,
> I have used grass64 -text to run
> "r.watershed --wps-process-description > r_watershed_process.xml"
Unfortunately "r.watershed --wps-process-description" only works with grass7.
> and
> "r.watershed --interface-description > gui.xml"
> GUI.XML is created but it is the size of zero byte.
Can you see the XML content when executing "r.watershed
--interface-description" in the shell?
BTW, you need to use a unix shell like sh or bash to redirect the
output of the command into a file using ">".
What operation system are you using?
Soeren
> please help.
> Sandip
> 2011/11/15 Sören Gebbert <soerengebbert at googlemail.com>
>> > Dear Martin,
>> > I am using WXPYTHON.
>> > So, where I can use this comand "r.watershed--interface-description"
>> > Please help me.
>> Open a GRASS shell and type:
>> To create a XML file, type:
>> Don't forget the space between r.watershed and --interface-description.
>> In case you want a WPS XML process description to use with PyXB type:
>> Soeren
>> > sandip
>> > On Tue, Nov 15, 2011 at 4:26 PM, Martin Landa <landa.martin at gmail.com>
>> >> > Dear frnd,
>> >> > I am not getting "-interface-description".
>> >> > Please suggest me how can i get gui.xml?
>> >> ML
>> >> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
>> > _______________________________________________
>> > grass-dev mailing list
>> > grass-dev at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/grass-dev
