[GRASS-dev] How can I cange or modify the GUI for watershed
analysis?
Sandip Maity
sandip.stesalit at gmail.com
Tue Nov 15 07:46:05 EST 2011
Dear soren,
I am using windows xp.
sandip
2011/11/15 Sören Gebbert <soerengebbert at googlemail.com>
> 2011/11/15 Sandip Maity <sandip.stesalit at gmail.com>:
> > Dear Soren,
> > I have used grass64 -text to run
> > "r.watershed --wps-process-description > r_watershed_process.xml"
> Unfortunately "r.watershed --wps-process-description" only works with
> grass7.
> > and
> > "r.watershed --interface-description > gui.xml"
> > GUI.XML is created but it is the size of zero byte.
> Can you see the XML content when executing "r.watershed
> --interface-description" in the shell?
> BTW, you need to use a unix shell like sh or bash to redirect the
> output of the command into a file using ">".
> What operation system are you using?
> Soeren
> > please help.
> > Sandip
> >> > Dear Martin,
> >> > I am using WXPYTHON.
> >> > So, where I can use this comand "r.watershed--interface-description"
> >> > Please help me.
> >> Open a GRASS shell and type:
> >> To create a XML file, type:
> >> Don't forget the space between r.watershed and --interface-description.
> >> In case you want a WPS XML process description to use with PyXB type:
> >> Soeren
> >> > sandip
> >> > On Tue, Nov 15, 2011 at 4:26 PM, Martin Landa <landa.martin at gmail.com
> >> >> > Dear frnd,
> >> >> > I am not getting "-interface-description".
> >> >> > Please suggest me how can i get gui.xml?
> >> >> ML
> >> >> Martin Landa <landa.martin gmail.com> *
> http://geo.fsv.cvut.cz/~landa
> >> > _______________________________________________
> >> > grass-dev mailing list
> >> > grass-dev at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20111115/1f5be7b3/attachment-0001.html
