[GRASS-dev] Re: [GRASS GIS] #1388: r3.univar gives bad results for
cell counts
trac at osgeo.org
Wed Nov 16 02:32:54 EST 2011
#1388: r3.univar gives bad results for cell counts
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: closed
Priority: critical | Milestone: 6.4.2
Component: Raster | Version: svn-develbranch6
Resolution: fixed | Keywords: r3.univar
Platform: Linux | Cpu: x86-32
Changes (by hamish):
* status: new => closed
* resolution: => fixed
Comment:
r3.univar tested using the example above & confirmed ok in all branches;
closing ticket.
I am not sure if the `r3.in.ascii type=float` + `r3.to.rast` error
mentioned in comment:5 is now fixed or not, I suspect it isn't.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1388#comment:7>
