[GRASS-dev] Fedora 16 6.4 release branch 49406 and RC2 failure
Markus Metz markus.metz.giswork at googlemail.com
Mon Nov 28 08:20:04 EST 2011
Roger Bivand wrote:
> Hi,
> I first tried 6.4.2 RC2, now also checked out SVN 49406, with the same
> result. With fresh Fedora 16, building from source (with 6.4.1 the proj
> arguments were never needed), there is trouble loading the GUI:
wxNviz has been disabled only 3 days ago in 6.4, latest svn works for
me with Fedora 16. This is not a real solution to
[snip]
>  File
> "/home/rsb/topics/GRASS/G642RC2/grass-6.4.2svn/etc/wxpython/gui_modules/wxnviz.py",
> line 58, in <module>
>    errtype = CFUNCTYPE(UNCHECKED(c_int), String, c_int)
> NameError: name 'UNCHECKED' is not defined
> GRASS 6.4.2svn (spearfish60):~/topics/GRASS/grass64_release >
> Any ideas? Worth filing a bug? Is this wx, nviz, ctypes, none of them?
but at least grass starts with gui, although without wxnviz.
Markus M
