[GRASS-dev] Fedora 16 6.4 release branch 49406 and RC2 failure
Roger Bivand Roger.Bivand at nhh.no
Mon Nov 28 08:38:00 EST 2011
On Mon, 28 Nov 2011, Markus Metz wrote:
> Roger Bivand wrote:
>> Hi,
>> I first tried 6.4.2 RC2, now also checked out SVN 49406, with the same
>> result. With fresh Fedora 16, building from source (with 6.4.1 the proj
>> arguments were never needed), there is trouble loading the GUI:
> wxNviz has been disabled only 3 days ago in 6.4, latest svn works for
> me with Fedora 16. This is not a real solution to
Martin wrote on Friday that he had disabled wxNviz in relbr64 at r49360,
so I assumed that by checking out r49406, I would avoid the problem I had
seen in the RC2 tarball. Am I missing a dependency that is not being
trapped by configure? Why does a post-r49360 checkout from:
svn checkout https://svn.osgeo.org/grass/grass/branches/releasebranch_6_4
grass64_release
still try to build wxnviz? Where should I look to see which files were
changed by r49360 on the server, so that I can compare with the ones I
checked out?
Roger
> [snip]
>>  File
>> "/home/rsb/topics/GRASS/G642RC2/grass-6.4.2svn/etc/wxpython/gui_modules/wxnviz.py",
>> line 58, in <module>
>>    errtype = CFUNCTYPE(UNCHECKED(c_int), String, c_int)
>> NameError: name 'UNCHECKED' is not defined
>> GRASS 6.4.2svn (spearfish60):~/topics/GRASS/grass64_release >
>> Any ideas? Worth filing a bug? Is this wx, nviz, ctypes, none of them?
> but at least grass starts with gui, although without wxnviz.
> Markus M
Roger Bivand
Department of Economics, NHH Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
