[GRASS-dev] Fedora 16 6.4 release branch 49406 and RC2 failure
Roger Bivand Roger.Bivand at nhh.no
Mon Nov 28 10:34:03 EST 2011
On Mon, 28 Nov 2011, Roger Bivand wrote:
> On Mon, 28 Nov 2011, Markus Metz wrote:
>> Roger Bivand wrote:
>>> Hi,
>>> I first tried 6.4.2 RC2, now also checked out SVN 49406, with the same
>>> result. With fresh Fedora 16, building from source (with 6.4.1 the proj
>>> arguments were never needed), there is trouble loading the GUI:
>> wxNviz has been disabled only 3 days ago in 6.4, latest svn works for
>> me with Fedora 16. This is not a real solution to
> Martin wrote on Friday that he had disabled wxNviz in relbr64 at r49360, so I
> assumed that by checking out r49406, I would avoid the problem I had seen in
> the RC2 tarball. Am I missing a dependency that is not being trapped by
> configure? Why does a post-r49360 checkout from:
> svn checkout https://svn.osgeo.org/grass/grass/branches/releasebranch_6_4
> grass64_release
> still try to build wxnviz? Where should I look to see which files were
> changed by r49360 on the server, so that I can compare with the ones I
> checked out?
The file on my checkout and currently shown from:
http://svn.osgeo.org/grass/grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/nviz.py
has lines 31-33:
     import wxnviz
     # disable wxNviz for 6.4.2
     # TODO: backport wxNviz from devbr6 *after* releasing 6.4.2
     haveNviz = False
but this doesn't seem OK for my context. The problem is the failure at:
     errtype = CFUNCTYPE(UNCHECKED(c_int), String, c_int)
NameError: name 'UNCHECKED' is not defined
so the import wxnwiz fails, doesn't it? Is just setting haveNviz = False
enough?
Roger
> Roger
>> [snip]
>>>  File
>>> "/home/rsb/topics/GRASS/G642RC2/grass-6.4.2svn/etc/wxpython/gui_modules/wxnviz.py",
>>> line 58, in <module>
>>> GRASS 6.4.2svn (spearfish60):~/topics/GRASS/grass64_release >
>>> Any ideas? Worth filing a bug? Is this wx, nviz, ctypes, none of them?
>> but at least grass starts with gui, although without wxnviz.
>> Markus M
Roger Bivand
Department of Economics, NHH Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
